Aft Shower woes 396
- 650Guy
- Captain
- Been thanked: 37 times
Aft Shower woes 396
Has anyone seen this and how did you fix it? from what I can tell, this piece of wood goes all the way around the shower door. Across the bottom, up the right, hinged side; and then across the top.
Kinda feel like I just opened a can of worms I really didn't want to... but now have to.
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Aft Shower woes 396
- 650Guy
- Captain
Maybe a call to Caver on Monday might be a good move.
- Has thanked: 78 times
- Been thanked: 1093 times
I'm actually surprised it's even wood. With that vintage, I'd expect some type of composite and I'd probably be looking at some composite options to replace it.
- 650Guy
- Captain
- 650Guy
- Captain
So I have gotten the entire shower wall opened up and thought I’d document what I find and how I fix it to help anyone else that may come across this issue.
1). The entire wall is just 3 pieces kept in place by silicon. Each seam held together by a u-channel then silicone seals it.
2) the base is self supporting, the front wood that has rotted in my case, is simply cosmetic with the exception of mounting the shower door.
In the pictures below, piece one is a single piece of wood. Basically the cut out the section for the shower door. The right side, the piano hing is screwed into the molding.
Picture 2 is what is behind the wood at the base. Along the floor, there is a small channel that the wood sits in.
Picture 3;shows from inside looking at the cabinet.
I have contracted a company to make the pieces out of composite. They are measuring and will build the curve into each piece. Once I get the pieces and start installing I will take more photos and provide the name of the place that made the parts to help anyone else out.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Just an FYI.
Greg
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Tireless wrote:Source of the post I have the same shower that may require some attention. Using a composite product like starboard may be a great idea as it is impervious to water, but some of those products will not adhere to a sealant. Make sure you can use a sealant with what you decide to go with, as there may be a slight chance it will not adhere. I had some starboard work done by a dealer on my first boat at the time of purchase and they told me sealant will not stick or make a seal.
Just an FYI.
Greg
A quote from another forum regarding starboard and adhesive. “One tricky thing to remember about actual Starboard (and not just other generic sorts of PVC lumber) is that it requires it's own special adhesive to get it to stick properly. So if you use it be prepared to either deal with their spendy two-part glue or arrange the design such that you can use mechanical fasteners to hold things in place.”
- 650Guy
- Captain
I should have more info this week and will continue to update this string on my progress.
Funny part is, this little project started out as my EASIEST winter job... Simply fixing all the caulk around my shower. HOW BAD COULD THAT BE?? hahahahahaha.
- Has thanked: 469 times
- Been thanked: 1765 times
