Trouble shooting AC on 3697
Topic author
woodyboater
Vessel Info: 1985 Carver Mariner 3697, Twin Crusader 454, Grand Lake of the Cherokees, OK
Postby woodyboater » July 20th, 2015, 8:47 am
We got on the boat Fri evening and turned on the AC and both units started cooling. Went outside and sat and started some cleaning and when we went back in the main salon unit had quit. No life. Checked the breaker and it is working. Checked the inline fuse behind the switch and it is good. Any suggestions?
1985 Carver Mariner
1959 Chris Craft 18' Continental
1956 Chris Craft 15' Cavalier
Has thanked: 64 times
Been thanked: 481 times
Re: Trouble shooting AC on 3697
Postby waybomb » July 20th, 2015, 12:01 pm
The breaker is working, meaning, you checked volts with a vom at the breaker and at the ac unit?
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » July 20th, 2015, 8:14 pm
I agree with Fred. Back to basics and ensure there is power at the unit before you go any further.
Topic author
woodyboater
Postby woodyboater » July 23rd, 2015, 12:10 pm
Thanks for the replies.
Was trying to check power at the switch but couldn't get any results across any of the switch connections or the wire spade connectors. My meter didn't have continuity capability so I bought another one that does have. I'll check the switch for continuity this weekend. Inside the blue power box, is there a fuse similar to a house AC unit?
1985 Carver Mariner
Topic author
woodyboater
Postby woodyboater » July 26th, 2015, 8:22 am
Got to the boat Fri nite and girl friend had the V-Berth AC running. Thought I would see if the main salon would run. Turned it on and it started up and compressor started cooling. Thought it might have gotten too cold and froze up so I turned the temp up and the compressor stopped. I thought 'oh crap' and (without thinking) immediately turned the temp down. As the compressor started something clicked (like a rest button) and the unit went off. Is there another breaker/reset button someplace other than the main elect panel?
1985 Carver Mariner
Postby waybomb » July 26th, 2015, 11:37 am
I can't imagine there would be two protection devices.
I think my next step would be to look for electrical terminations in the area where you heard the click. Could be loose/corroded wires.
(turn the electric off first!)
Postby Viper » July 26th, 2015, 8:28 pm
If i'm reading you right; the compressor was running, then you shut it off, then you asked it to come back on again right away. If that's the case, the clicking you heard is the compressor's cutout kicking in which is normal when the compressor is forced to start up again right after a shut down. This forces it to try and start against high head pressure. Next time that happens, shut it off and wait a few minutes before asking it to turn back on again. This allows the head pressure to drop first and make it easier for the compressor to start.
Topic author
woodyboater
Postby woodyboater » July 27th, 2015, 8:52 am
Thanks,
I tried it several times over the weekend and it would not start blowing. Seems like after it set for a week that it reset itself and started this week. I'll try it again next weekend and see what happens.
1985 Carver Mariner
My Jurisdiction
Vessel Info: 1981 3007 aft cabin
Has thanked: 19 times
Been thanked: 3 times
Postby My Jurisdiction » October 2nd, 2015, 12:06 am
Check the strainer system for clogging. It has happen to me at dock. /sitting at dock the system can suck trash for the port your docked in.
