Forward Bilge Issue
- pendavmassey
- Vessel Info: 1988 Carver 3807 Aft Cabin
- Has thanked: 3 times
Forward Bilge Issue
It seems that the forward bilge is having issues. It doesn't seem to be able to drain the water from under the water tank in the galley. We do not have any schematics or owners manual. Is there an opening in the dividing wall between this area & the back of the boat that may be plugged? The access is very small & narrow. We have to rig a garden hose to our shop vac to remove the water as it seems that the pump has no where to drain it. Any help or suggestions would be greatly appreciated.
Thanks, Penny & Dave
Re: Forward Bilge Issue
If that's the same setup as yours, the real key might be finding where the water is coming from, as that area should stay completely dry. You could have a leaking shower sump or condensate drain line or some rainwater might be finding its way down there. Or you might have a minor plumbing leak.
- Has thanked: 474 times
You will always have a little water towards the bow as it sits a little lower than the most forward pump which is under the stairs at the galley. The bulkhead there separating the engine room from the lower area; galley, v-berth, etc., is open at the very bottom so any water ingress through the engine compartment makes its way forward. The pumps also sit on glassed pads which naturally elevates them a little higher. No bilge pump gets all the water out of a bilge so you'll always have water there if from nowhere else other than shaft logs.
For the water that collects in the bow, I just vacuum it out periodically through the forward most hatch in front of the bed. Don't let it sit for long so it won't stagnate and smell.
Do you have the old open shower sump with the external pump between the two tanks or has it been upgraded to the newer all in one enclosed style?
- rjr
- Vessel Info: 440 MY
- Has thanked: 25 times
- Been thanked: 9 times
https://www.amazon.com/s?k=marine+shower+sump+box&crid=25N0LGN3FWZI8&sprefix=marine+shower+sump%2Caps%2C249&ref=nb_sb_ss_ts-a-p_1_18
rjr wrote:Source of the post Not trying to hijack this thread - Viper: can you provide details on "the newer all in one enclosed style?" We have the open sump and external pump which I do not like. thanx
I did the upgrade on my aft shower sump in this thread:
viewtopic.php?f=13&t=5094
- rjr
- pendavmassey
- Superg
- Vessel Info: 1985 Carver 3207 Aft Cabin
Harbored in Lake St. Clair, MI - Location: Detroit, MI
- Has thanked: 4 times
- Been thanked: 20 times
viewtopic.php?f=11&t=5303
John
New Boat Owner (so lots to learn)
Harbored in St Clair Shores, MI
