Engine Synchronizer Gauge
- Raylap819
- Vessel Info: 1988 Carver 3807; twin GM 454s
- Has thanked: 26 times
- Been thanked: 654 times
Re: Engine Synchronizer Gauge
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
I have two RPM gauges and one small gauge in the middle that looks like a rudder stand indicator but underneath it is connected to a separate 'disk like box' and (I think) the RPM counters.
So I guess that this is said synchroniser. Is it supposed to synchronise by itself? (doubt it, it has no connection to the throttle cables)
Or only show which engine is running a higher/lower RPM than the other? What is the point with that unless you also have a rudder indicator to know what is causing a deviation in course.
- Has thanked: 602 times
- Been thanked: 1310 times
Raylap819 wrote:Source of the post I have a 1989 3807 that has a broken glass on the Engine Synchro Gauge. Can I have the glass replaced or do I have to purchase a new gauge? It was broken when I purchased boat.
I guess by the time you find someone to repair the gauge it may cost way more than just a new instrument.....the replacement is fairly straightforward if you are handy.
Just need to check what is required with any gauge ( sending module or such ), maybe with yours it is just the gauge itself if you can get a direct replacement.
I believe Viper has the same boat, maybe he has the gauge you are referring to.
- Been thanked: 1111 times
Phrancus wrote:Source of the post
That's the correct function, just compares the two engine tachometers to display which one is reading higher. When the tachs are within a couple hundred RPM, it's hard to read them accurately enough, but the sync gauge will show which one is higher. On older engines without really good exhaust mufflers, it was easy to tell by the sound of the motors.
Are your gauges mounted over/on top of the panel or under it?
- Raylap819
- Raylap819
Users browsing this forum: No registered users and 118 guests
