Run Dry Impellers
Re: Run Dry Impellers
- Been thanked: 1111 times
pepmyster wrote:Source of the post Hans, Don't shoot me. I'm one of those guys who also that use the pink stuff. Mind you, never had a problem, (knock on wood),but can see the long term affects happening, especially for someone who is not an up to date maintenance kinda guy.
But, this coming winter, let's get through summer first, I will be changing over to the good stuff. I need to do the impellers this spring also. Points taken on the pink juice, and they all make sense. You know, you'll still get people who have their own ways .
Just because it's pink doesn't mean it's the alcohol-based stuff. Some is poly and some is alcohol. The one big clue is the 'flammable' indication on the sticker, as Hans notes.
I stand corrected, just so used to using pink when I refer to "safe" anti freeze. Glycol based anti freeze and alcohol based antifreeze does come in other colors but I must say I have never seen any in person, only on the net.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Been thanked: 490 times
I have not performed a preventative change on any of other current or past boats. I keep impellers and housings on board, and tools.
The only failure I ever had was the first year we had the 4207 and had to keep it outside/winterized. I started the engines when putting it back in the water, duh, without opening the sea cocks. That's it, never lost an impeller other than the dumb incident. Had boats since 1988.
- Metterdvm
- Vessel Info: 2003 Carver 356
This was a pretty hefty bill for which the owner tried to get covered by insurance. The adjuster came out, took a look, was surprised at the damage, then smiled when he saw the impeller! This wasn't an accident, it was neglect, a lack of maintenance, it was inevitable/just a matter of time. Needless to say, the owner had to cover all the costs. Thousands of dollars and a summer lost for the cost of replacing impellers. Just because you've always gotten away with something in the past doesn't mean you always will.
- Has thanked: 602 times
- Been thanked: 1310 times
I have noticed and warned more than a few boaters leaving the harbor with a loud engine and no or greatly reduced/steamy water flow......it is quite obvious to me anyway.......
- Cooler
Users browsing this forum: Google [Bot] and 9 guests
