Water under hatch
- Icango560
- Vessel Info: 2004 Carver Voyager 560, 675 Volvo’s.
Water under hatch
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Water under hatch
- Icango560
- VolNavy91
- Vessel Info: 1997 Carver 400 CMY
1st Date
Paris Landing, TN - Location: Bartlett, TN
- Has thanked: 17 times
- Carpediem
- Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
- Has thanked: 2 times
- Been thanked: 25 times
Icango560 wrote:Source of the post Thanks, I can’t find anything that dumps to the cavity. I vacuum the water out and it may stay dry for several days. Then it comes back. It looks like clean fresh water.
Have you tried turning off the fresh water supply for a while? I know over on the Searay forum there were several threads involving mysterious water in bilge areas where not expected and thye found many times to be small leaks in the fresh water system at bad joints. Also if it only accumulates while or after being underway the water can me migrating from some where forward like an AC pan. Always fun to find.
These leaks can be a challenge to source. The key is to eliminate one system at a time and do some critical thinking like; does it only happen when I take the boat out? Does it happen if I just run the engine in the slip? Does it only happen when it rains? Is there water there when I shut the pump of, depressurize the system and stay away for a week with the dockside water off? Does water collect if I don't use the AC/heat? If there is a shower sump close by, is it working properly?, etc. Once you eliminate some possibilities, it's easier to narrow down the cause. Short of the cause being one of the items above, the only other thing I can think of is checking any hardware that goes through the hull. So that's rudders, shafts, intakes, seacocks, discharges, all hoses, any signs of leaks around the washer dryer?, etc.
Good luck and keep us posted
- Been thanked: 646 times
- Has thanked: 598 times
- Been thanked: 1281 times
Icango560 wrote:Source of the post There are several hatches in the Master stateroom on our 560 Carver Voyager. The small hatch at the foot of the bed collects water. I have been unable to detect where it is coming from. I stopped up entry holes on either side. Any ideas? Thanks
Here is something that has worked for me.......dry the area you are talking about, then put down dry rolled up towels around that area and check them regularly and see which one or ones get wet...then you will know the direction to concentrate on and expand out the same way....it will work to narrow down where the water is coming from.......good luck ....
- Icango560
- Icango560
Thanks again
Larry
Users browsing this forum: Google [Bot] and 12 guests
