Carver 32 convertible
Carver 32
Vessel Info: 3227 convertible
Postby Carver 32 » February 6th, 2021, 5:49 pm
:captain: so I’m a new owner to a carver 32 convertible and I’m just trying to figure out how far can I travel on a full tank of fuel ? Any help on this will be greatly appreciated!
Re: Carver 32 convertible
Postby Viper » February 6th, 2021, 6:31 pm
Congrats and welcome aboard. Hopefully someone with the same model will chime in. What is the model year?
Been thanked: 491 times
Postby waybomb » February 6th, 2021, 7:34 pm
Welcome aboard!
Carver 32
Postby Carver 32 » February 6th, 2021, 7:51 pm
Viper wrote:Source of the post Congrats and welcome aboard. Hopefully someone with the same model will chime in. What is the model year?
1994 32’ convertible
Postby Viper » February 6th, 2021, 8:19 pm
I should have asked before; it'll help if the guys knew engine make and model too as there will be different fuel burn rates depending on what you have. The more info you can provide the better.
Postby g36 » February 6th, 2021, 9:41 pm
Here's a website you can use to give a estimate just pick your engines and it gives fuel burn at various rpms. https://www.boat-fuel-economy.com/fuel- ... calculator
Been thanked: 470 times
Postby RGrew176 » February 7th, 2021, 1:42 am
Welcome Aboard. Good luck with your Carver.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » February 8th, 2021, 6:15 pm
With a vessel in that age category, the only way to get an accurate read is to fill the tanks, cruise them down to 1/4 tanks, and keep a log. Refill, with the expectation you will take on 140 gallons. Different engines will perform at different ranges, even if the same brand/model. Way too many variations here,- boat hull condition, tune up schedule, throttle habits, drive alignment, transmission condition, quality of fuel, wind, water action, to name a few. One rule of thumb is 1 mile per gallon. You have 188 gallon capacity, assume 350 Crusaders because that was what a lot of the 94's had installed with BW V-drives, an average of 3200 RPM. So, a purely generic answer would be 188 miles. Absent the practice above, that is all I would expect for planning, and I would not exceed 159 miles before I would have access to a fuel source. Good luck. 8-) er
Cooler By The Lake
Users browsing this forum: No registered users and 50 guests
