Heater not heating above 72
- Captdoug
- Vessel Info: Carver 42 SS 2006
Re: Heater not heating above 72
You should start by checking and cleaning the inlet strainer before the ac pump. If that's clean, you need to clean all of the lines and heat exchangers.
If you don't have any flow, you wont have any heat, or A/C.
- Been thanked: 654 times
If you're sure the AC pump is running but no water coming out of the AC discharge fittings, maybe it's as simple as needing to prime the pump. You also need to ensure that all the strainer is clear as Tom mentioned. Also make sure the air intake screens and evaporators are clean as dirty ones will affect efficiency.
- Captdoug
- Captdoug
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
- Captdoug
