Size and number of duck bills
- Has thanked: 474 times
Re: Size and number of duck bills
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
- thatchh
- Vessel Info: 2004 Carver 396ES gas Crusader 8.1
- Been thanked: 11 times
- tgebler
I lightly lubricate the base of the valves so they slide a bit when you're tightening the fittings back together. I find that if you install them dry, they catch and twist inside the fitting. This causes them to distort and open up which will cause the system to leak. When that happens, you'll think that since you just replaced the valves the leak must be elsewhere and spend an eternity trying to find one that doesn't exist. Dish soap works fine.
Oh and don't forget a clothes pin.....for your nose
Good luck
- tgebler
