1994 390CPMY 11 gallon water heater
Been thanked: 1111 times
Re: 1994 390CPMY 11 gallon water heater
Postby km1125 » March 20th, 2021, 7:33 pm
On mine there wasn't a visible thermostat, but if you removed the cover the temperature control device was adjustable.
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » March 20th, 2021, 8:10 pm
I did remove my cover where the wires go in. No stat here.
Postby Viper » March 20th, 2021, 8:22 pm
The thermostat is a set thermal type round switch. Their high limit switches were round and usually had a little red reset button on them. There must be a stat and limit switch.
Postby tomschauer » March 20th, 2021, 10:31 pm
Thermostat and high limit cut out are on the front of the unit where your 120v wiring enters. The stock units are not adjustable.
Postby Viper » March 20th, 2021, 11:15 pm
Tom is correct. Your hot AC wire will be going through the stat and limit switch before heading on to the heating element.
Postby tomschauer » March 20th, 2021, 11:23 pm
You have a klixon thermostat and and a klixon resettable high limit switch. At least you should.
These are round, about the diameter of a quarter. The high limit should have a very small red stem for resetting.
Been thanked: 1310 times
Postby bud37 » March 21st, 2021, 8:55 pm
All water heaters should have a safety circuit of some sort with a high limit and temp control or there can be catastrophic results ( can explode) if the heat stays on and the relief valve fails.Try to find yours and determine if it works correctly.
tonyiiiafl
Postby tonyiiiafl » March 22nd, 2021, 4:27 am
[quote][/quote]
Mine DOES turn on and turn off, just nothing I saw under that cover. Going to dig in again.
