safety breaker panel access
- aloysius
- Vessel Info: 2000 Carver 406
- Has thanked: 16 times
- Been thanked: 3 times
i.e. My quest is to discover how this is wired and incorporating that into the electrical diagram for my boat.
Re: safety breaker panel access
- Been thanked: 654 times
- aloysius
I'm investigating all of this because my Charles charger is old and acting up. I have 5 batteries in the center bilge area of my 406. The aft two are hooked in parallel and supply ALL the DC equipment on board except the stereo system. Oddly, the two next forward batteries (hooked together in parallel) supply the stereo system and nothing else. The 5th and forwardmost battery is the starting battery for the genset.
My charger seems to be charging the two aft batteries through breaker switches 1 and 3. Number 2 charger breaker (which should have been used to charge the gen set battery) charges the two batteries supplying the stereo.
I can not see much on the back of the power panel in the lower step because of the limited view and the conglomeration of wires. A schematic of how this panel is wired is my first goal and then to wire the battery charger correctly second, and finally wire in the inverter and stereo in such a manner that the next owner will not turn to abusing alcohol.
Any further assistance or advice you can give me would be appreciated.
Thank you so very much!
- Has thanked: 602 times
- Been thanked: 1310 times
- Phrancus
- Been thanked: 136 times
- Contact:
I had planned to rewire the whole panel but found that most wiring is original, only some modifications were done and most markings are gone. But all is fused and switched so I will just clean, mount and renovate were needed 'only'.
Found the wiring scheme on the carver website and most of it is correct to my boat. I'ts not a complex scheme, just the colors and some of the markings are what you need to get a picture of how it is set up.
Even for charging, you don't need very much. It is nice, and luxury to have a central unit control use and charging but this can be done separately as well if need be.
For example: I have a central controller for the 3 battery banks (of which at the moment 1 bank is missing but thats another story) and I can hook up a charger to it and it will take care of efficiently charging all banks.
That charger was broken when I got the boat so I put two cheap chargers directly on the batteries. So when in port, shore power will charge the batteries. Not in a smart order but I don't care about that: theres lots of time for all batteries to be fully charged before I get back to the boat.
I will of course set this all right but here too: accessibility is an issue. The stairs are apparently a popular place to put stuff under and without taking care of access like flipping the whole thing over. Yes, I will make sure I modify the stairs that way.
- aloysius
