A/C raw water pump
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Re: A/C raw water pump
The flow on AC units is not very critical, easily seen at the marina where some seem to throw water 5 feet horizontal where others barely clear the hull. Not sure what I have but its not very big as water flow is rather weak out of the 3 outlets.
True story, AC died on my previous boat and was not able to get a pump for over a couple of weeks during some nasty hot weather. Went to the local pet shop and purchased an aquarium pump as a temp fix for less than $100, worked perfectly. Those little pumps are pretty decent, have a salt water tank which I started in May of 2011, 24/7 pumping 250 gph, original pump still works fine after 10 years.
This is not an endorsement to do the same.Here is a good example of a very high quality magnetic drive pump @ 480 gph. Remember, these are meant to run 24/7 so they need to be well made. https://www.aquacave.com/blueline-20-hd ... world.html
Here you can see the choice is rather huge. Some of those bad boys will do 9,000 + gph. If it said "marine" on those units, just multiply the cost by 10 and you will be in the ball park.
https://www.aquacave.com/catalogsearch/ ... avestate=1- tonyiiiafl
- tonyiiiafl
- Been thanked: 1111 times
bud37 wrote:Source of the post How many GPH is the pump that is there now ? If it works properly then just replace with the same whatever that is...if it is not working efficiently then an upgrade would be wise.... be aware in this case, more is not better as in heat exchangers the important thing is contact time to transfer heat...it can be over done.
In most cases that's a misnomer.
With more fluid flow you transfer less BTUs/gallon of coolant, but you're flowing more coolant so it usually more actual BTUs that get exchanged. In the cases where that doesn't happen (like when someone removes their thermostat), it's not the increased flow that's the issue, it's that you disrupted the normal flow pattern so much that certain areas don't get cooled at all.
- Has thanked: 602 times
- Been thanked: 1310 times
km1125 wrote:Source of the postbud37 wrote:Source of the post How many GPH is the pump that is there now ? If it works properly then just replace with the same whatever that is...if it is not working efficiently then an upgrade would be wise.... be aware in this case, more is not better as in heat exchangers the important thing is contact time to transfer heat...it can be over done.
That is true but a lot depends on the circumstance and specs for the system you are considering.....but in the context of this thread I believe it would be wise to stick with close to the original spec as that was the design. There is a reason they spec a particular GPH for their system efficiency IMO and experience. Contact time is affected by turbulence and fluid velocity, but that goes way beyond the discussion needed here. There is piping size, hose restrictions, power needs, wiring etc to consider if one were to oversize the system gph too much, and like I said ..it can be overdone, meaning not to go too far for no reasonable gain.
No matter how high you go with your pump spec, you're only going to move a certain amount of water through a given size of condenser tubing. You might change pressures and volume a bit depending on the pump but eventually it will reach a point where it can't push any more even if it hasn't reached it rated output. While this might tax a typical pump with a mechanically/shaft driven impeller, the good thing about the ones we use for this application is that they're magnetically run. If rated output is restricted, it's not that big a deal on the pump.
- tonyiiiafl
