Transom Swim Step Bracket Issue
- gmac98004
- Vessel Info: Proud new owner - '98 355 Aft Cabin "Invictus"
6BT5.9M 210hp
Formerly - 1986 - 30' Newport MKIII - Location: Shelter Bay, WA
- Has thanked: 451 times
- Been thanked: 12 times
We purchased our 1998 - 355 AC last year. Survey did indicate that this ladder bracket as an issue needing a fix. Now that we’ve hauled out, I’d like to address this somehow.
Does anyone have a suggestion on how I may go about tackling this issue?
There doesn’t seem to be saturated material above those bolts in the transom. But it’s possible there is some saturated material around the cracks.
I would appreciate any recommendations on how to address this one! We're not keen on using that ladder at this point. So it's not essential it becomes fully functional for us. More concerned about the water intrusion and further damage to the transom.
Many Thanks, Greg
Re: Transom Swim Step Bracket Issue
I would open the access and get a camera in there and see what you can find out.
Looking at the damage, it looks like it is just glass in that area. If there is wood and it is soaked through then you may want to do some more serious repairs as opposed to just the backing plates.
I have a feeling they just put a small piece of wood in there for a backing plate that is all wet and soggy, chuck it, dry up the area and do the proper backing plate thing.
You definitely need to open the inspection cover and take a peek inside to see what is going on.
- Been thanked: 654 times
Ditch that ladder and get the under platform type that use a long bracket mounting that the ladder slides into for storage. The long bracket mount helps to spread the load when the ladder is used. These are way better and sturdier than the type you have on there now. It's also a good time to determine whether you need an extra step or two to make it easier to board. Just make sure it's not so long that it hits bottom when you have it down while anchored. A little wake and a bounce will wreck it.
Keep us posted.
- gmac98004
6BT5.9M 210hp
Just a few updates for you on this tricky ladder issue. Here are a few highlights based on some videos and inspections today:
1. The underside of this transom is indeed cored.
2. Bolts holding the ladder bracket are glassed in and cannot be removed with conventional DeWalt drill/screw guns.
3. I hung on the ladder and experienced no deflection at all even though there are clearly some cracks around the STBD bracket.
4. There was water in 2 of the 4 access caps. Not a lot but several tablespoons.
5. I could see no standing in the inner area. Lots of dust and flecks tells me there HASN'T been a lot of water in there.
6. Unfortunately, some of the balsa core I could inspect is damp thought certainly not squishy or soaked.
7. The rusty access cap you see is due to previous owner leaving a wrench 3" from this access cover!
The yard is dropping me back in the water on Friday. I'm inclined to Dremel deep into the cracks and fill with Marine Tex. Not sure I have time at this point to deal with the damp balsa on the port side.
Other than 4200 around all 4 access covers just to be safe, I'm not sure what I can do in the limited time I have out of water.
Anyway, your thoughts and suggestions are all valuable and I appreciate it! Let me know if I'm crazy!
Thanks Again, Greg
- Has thanked: 602 times
- Been thanked: 1310 times
Most times the inside area is not finished and very rough and irregular, an inspection is required before bolting up. Try to avoid this by sanding flat the area where the backer goes then using a wood backer or bed the backer if it is metal in epoxy/marine tex etc.....just snug the plate down a little, then final tighten after the epoxy hardens. This will fill in all the irregularities and stop the damage to the shiny gel side as the pressure will be applied evenly.
I agree, that ladder just doesn't work for me, too bad you didn't have more time but if you seal up the cracking area properly like you say it may buy some time.....good luck with your project.
I wonder why someone cut in all of those access holes? There where none from the factory.
I would make sure the o-rings are all good when you close them back up or you will get water in there.
- mjk1040
- Been thanked: 248 times
Users browsing this forum: No registered users and 45 guests
