Leak in fresh water line under sink in the galley
- 4207Carver88
- Vessel Info: 1988 4207 Aft
- Has thanked: 5 times
My wife and I are living the dream living aboard our 1988 4207 in The Northeast. We bought her after our wedding this past October and call it our extended honeymoon. Let’s be real, waking up on the water makes everyday feel like you’re on vacation and I’m not sure what could be better! Either way, as the weather is breaking we are taking down the small projects getting ready to run most weekends in the spring summer and fall. Here’s my question, I have a small leak in the fresh water line under the sink in the galley. I know it is the fresh line because it just doesn’t have the same pressure as the hot line when turned on. I just don’t know how to access the line short of cutting into the glass. I spoke with Carver and they said there should be access to it somewhere in the cabinets but I can’t seem to find anything that would allow me to unscrew the fitting. I know about the access under the wet bar in the salon but that really only gets me directly above it. Any advice/ideas would be very helpful! I appreciate it in advance! All the Best -Joey
Re: Leak in fresh water line under sink in the galley
Are you saying hot water comes out stronger than cold water at the tap? If so then the faucet cartridge would be at fault, not the plumbing.
Welcome aboard by the way.
- 4207Carver88
Thanks!
As for the hissing sound are you sure this is just not water running through the tap/lines or is this sound there all the time? If it is there all the time try shutting off the pump , open the tap until little or no water comes out and listen once more. If it is still present then nothing to do with the water.
- 4207Carver88
Really appreciate all the insight btw!
Han's was probably thinking water pump.
Sorry, but I dont know how to access on your boat. A flash light and some time may help.
Usually there are no plumbing connectors used in behind wall spaces that you can't get at, just the water lines so the chances of leaks are minimized. The back of fixtures can leak. Shower and tub fixtures are notoriously hard to get to and the only clue that there is something wrong is a sound and water in the bilge space below, so that's a possibility.
With your Fresh water system pump turned on, does it cycle periodically even though you haven't opened any faucets? That is a telltale sign that it's a fresh water system leak or bad pump. If the pump doesn't cycle when faucets aren't opened for an extended period, it's likely not a fresh water leak.
Do you have lower cold water pressure in all the faucets or just one? Did this just start happening or always there since you bought the boat?
- 4207Carver88
What reinforces the fact that’s it’s the fresh water system is just what you said. When the pump is on and without opening the faucets the pump runs every 15 mins and will empty the tanks. It has to be a leak I just don’t know how to get access.
- 4207Carver88
Users browsing this forum: No registered users and 42 guests
