Dingy Davits
- tjh408
- Vessel Info: 2003 Carver 360 Sport Sedan
- Has thanked: 18 times
- Been thanked: 9 times
Dingy Davits
Thanks for your comments
- amyelias
- Has thanked: 1 time
- Been thanked: 4 times
Re: Dingy Davits
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Dingy Davits
I looked at them when I was shopping for a davit systems as well, but do to my limited space on the swim platform, it was too narrow for this set up and I required a system with extensions to make it work.
Your boat is clearly wide enough for a 10'6" dinghy at 13'6", however, you need to sure that the depth of your swim platform will accommodate this system with your dinghy. You need to measure the depth of your swim platform from the back edge to the fender racks. You should also divide the width of your dinghy in half to determine if your swim platform will accommodate half the width of your dinghy. The H 30 also will totally mount on the swim platform so you need to add that to your swim platform. Not sure if the have extensions for that systems yet.
Contact Hurley with your dimensions and they will tell you if you have enough room for the H30 system and your dinghy. You may require a system that allows you to extend off the end of you swim platform.
I had a 1999 Carver 356 and I had the swim platform extended by 40". I installed the standard Hurley set up and it was fantastic. The keel of my dinghy sat at the back edge of the platform. The area of the platform that was covered by the dinghy was half the width of the dinghy, at 2.5'. With this system I had to pull my dinghy up sideways onto two rudders and strap it down. This was a great and reasonably priced system for my 11' Brigg with 9.9 outboard.
Hope this helps.
Greg
- amyelias
Re: Dingy Davits
- Iwantacarver
Hey guys , what’s the best place to get that wood flooring
Anyone know where I can get it? Can I do it myself
- tjh408
Re: Dingy Davits
- Tireless
Re: Dingy Davits
Greg
- Been thanked: 654 times
Re: Dingy Davits
Tireless wrote:Source of the post
Greg
Do you care to post the info on the extension? I ve seen one from swimplatform.com is this it or other? Thanks
Re: Hey guys , what’s the best place to get that wood flooring
- Tireless
Re: Dingy Davits
The tech installed fibreglass SS brackets onto the transom and ran 1” plus SS square tube (4) from the brackets to the bottom of the swim platform. The platform was bolted to the edge of the OM’s swim platform edge and fibreglassed into place.
I believe they still do them, but they are located in Keswick, Ontario, Canada.
I was advised that the retail for the platform was $12,000 and the soft cost would have been $6,000. I had it included as part of the purchase arrangements when I bought the boat.
This was the best thing I could have done for the boat. It was large enough to accommodate people, chairs and coolers, however, it did not interfere with getting the boat out of the pocket and on plain. Also gave me a lot of room to store the dinghy flat on the Hurley Davit system with lots of room to move around.
I will post some pictures in a moment.
Greg
