Carver 530 EDC control panel
kkochner
Vessel Info: 1998 Carver 530 Voyager Pilothouse
Postby kkochner » April 21st, 2021, 1:06 pm
Would anyone have or know where I could get the attached EDC control panel? Thanks so much...any help greatly appreciated!!!
Volvo D-12 Diesel Engines
Port of Tulsa OK
Re: Carver 530 EDC control panel
Postby Viper » April 21st, 2021, 3:14 pm
I might be able to find it if you post an engine serial number. Hopefully the assembly will be associated with it. Not having any luck just looking through a D-12 parts breakdown on Volvo EPC. Is there something wrong with the current one?
I did find this though....
https://www.ebay.com/itm/203338655508?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D231970%26meid%3D2cb69263a3b24d7cb413e10141af9ad5%26pid%3D101224%26rk%3D1%26rkt%3D5%26mehot%3Dnone%26sd%3D203180616985%26itm%3D203338655508%26pmt%3D0%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganic%26brand%3DVolvo+Penta&_trksid=p2047675.c101224.m-1
kkochner
Postby kkochner » April 21st, 2021, 3:48 pm
Here is the serial number info...thanks so much for ur assistance!!!
Port of Tulsa OK
kkochner
Postby kkochner » April 21st, 2021, 3:49 pm
My Pilothouse one needs new buttons:)
Port of Tulsa OK
Postby Viper » April 21st, 2021, 9:03 pm
Looks like this is the assembly. The button kits are still available, I just can't tell if the kit comes with all the lenses and symbols so you can choose the one you want to use. The lens and symbol plates aren't available individually anymore. You can order through a Volvo dealer or keep looking on eBay, I've seen the buttons available on there before.
kkochner
Postby kkochner » May 5th, 2021, 11:11 am
Thanks viper I appreciate the info...the replacement parts are pretty pricey. Hopefully I can find a used one:)
Port of Tulsa OK
Postby Viper » May 5th, 2021, 12:33 pm
Contact the guys in my eBay link above. They might have what you need.
TruckerTim
Vessel Info: 2000 Voyager 450
Sarasota, FL
Postby TruckerTim » July 6th, 2022, 4:33 pm
Resurrecting this old post as I am looking for these buttons as well. Did anyone find these? I trying the eBay link but appears that seller is no longer.
Carpediem
Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
Has thanked: 2 times
Been thanked: 25 times
Postby Carpediem » July 6th, 2022, 11:07 pm
I look up parts at Volvo parts online then just order them from my local Volvo Penta dealer. I have just resigned myself to the fact that Volvo is proud of their parts so fork over what they cost. I save on the back end by doing my own replacement. I think it would be a good idea to start investing in spares for things like the EDU and various sensors as these eventually will be harder and harder to source. It really sucks that these parts are so proprietary instead of off the shelve standard parts that could have been integrated.
Carpe Diem
Try to only boat where ducks don't walk
Postby Viper » July 7th, 2022, 6:56 am
I mentioned in my post above that parts are still available from Volvo for those panels. A dealer can order the parts if you can't find anything used on line.
