New member
- Rodwilson@mail.com
- Vessel Info: 1985 carver 3697
Re: New member
20210318_144325 ,20210318_144339, 20210318_144449,
- Been thanked: 1111 times
Re: New member
Is this what you have? (or something similar?)
That pic I just got off Amazon. Just searched for "stainless exhaust flange". That particular one is about $200
- Has thanked: 602 times
- Been thanked: 1310 times
Re: New member
Re: New member
bud37 wrote:Source of the post If it were mine on the next haul I would remove those fittings ( both sides ) and inspect what is going on there.....the reason, what concerns me from the pic is the brown tinged seepage stains. If water has gotten behind there it could be in the transom core and since replacement is in order anyway a good idea might be to have a real good check of those areas....probably not what you wanted to hear but that is my opinion from what I see.
Is there hull coring in a 3697? My same year 3607 didn't have any below the rub rail.
Re: New member
km1125 wrote:Source of the postbud37 wrote:Source of the post If it were mine on the next haul I would remove those fittings ( both sides ) and inspect what is going on there.....the reason, what concerns me from the pic is the brown tinged seepage stains. If water has gotten behind there it could be in the transom core and since replacement is in order anyway a good idea might be to have a real good check of those areas....probably not what you wanted to hear but that is my opinion from what I see.
I think it's interesting that the area just around the thru-hull looks like it was spray painted well after construction but before the leaks. Was that a previous owner? Wonder why they just sprayed that part and not the rest of the area of the bilge there?
Re: New member
km1125 wrote:Source of the post Is there hull coring in a 3697? My same year 3607 didn't have any below the rub rail.
I don't know what is in there......maybe the models are not all the same......like I said, the staining is what concerns me from a visual. Maybe just brackish water or rust , who knows. My guess about the paint could be some of the magic in a can ( you know what I mean ) and the only correct way to repair those fittings if in fact they have pinholes is to replace them. Even if the transom is solid glass layup you still don't want water to get to the glass fibres behind the gel.
Easily checked while changing the fittings.
Viper is good with glass, maybe he will chime in.
Re: New member
I too thought the white paint was strange. At first I thought it was a glass repair but I don't see any signs of that so I can't figure out why it was spray painted. I'd be curious to find out if it's that rubber spray stuff you see advertised on TV for waterproofing that they might have tried for stopping a leak. If it feels rubbery, I'd be willing to bet that's what it is.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: New member
