Head raw water inlet location?
Re: Head raw water inlet location?
Can you not just follow the water supply line which goes to the head? There must be a panel or 2 that you can unscrew to see where it goes.
- Has thanked: 474 times
What make and model is the head? Do you pump a handle, or push a button or pedal to flush?
- mikesparker
- Vessel Info: 1985 3227 w/Crusader 220s
- Has thanked: 28 times
- Been thanked: 3 times
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Take a pic of the base of the head. Also, when you follow the piping, did you see a solenoid valve?
Also, turn on the fresh water pump with water in the tank and see if you get water when you flush.
- mikesparker
- mikesparker
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
mikesparker wrote:Source of the post Two questions: Does the keel have a slight forward slope right at the galley? What is that access for?
Yes it does from what I remember, the access is good cause you can dry the bilge from there and my guess, it could be there to access options you may not have.
Good to hear the feedback and the memory isn't as bad as I thought......
Oh do you have the parkay style flooring in the galley area ?
