1983 Carver Mariner V drive cooling system help
- Fireriders
- Vessel Info: 1983 Carver Mariner Model 2897 twin Crusader 305's
- Has thanked: 6 times
- Contact:
- Has thanked: 469 times
- Been thanked: 1765 times
Re: 1983 Carver Mariner V drive cooling system help
- Fireriders
- Contact:
The other way those are plumbed in is to have two seacocks strictly for the v-drive and a separate one for the engine. With this setup, there is no raw water pump forcing water through the v-drive. On the drive's seacocks, one scoop faces forward and one faces aft. The motion of the boat through the water forces water through one of the seacocks, on through the drive's heat exchanger, then out the other seacock. this happens in forward and reverse. You need the boat to be moving for the drive to get cooling water so it's not a good idea to run the unit in gear for too long while tied to the dock. Take a look at which setup you have as this is important to note.
- Fireriders
- Contact:
- Fireriders
- Contact:
- Has thanked: 598 times
- Been thanked: 1281 times
Is the boat on stands now ?
- Fireriders
- Contact:
- Fireriders
- Contact:
Users browsing this forum: 650Guy and 31 guests
