1994 390CPMY interior wood
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » May 9th, 2021, 7:58 pm
DOs anyone know the interior wood used on a 1994 390CPMY? Cherry? Teak? I need to get. Some to replace a faux pas!
Been thanked: 1310 times
Re: 1994 390CPMY interior wood
Postby bud37 » May 9th, 2021, 8:36 pm
It may depend on what option was ordered, there may have been two or three choices of finish, not sure if they changed the wood veneer or just the finish......do you have a well lit pic of it....that may help someone to notice....good to hear things are going the right way.
Postby Viper » May 9th, 2021, 10:31 pm
Ya really depends on the build. A lot of them are cherry, mine is teak,...
tonyiiiafl
Postby tonyiiiafl » May 10th, 2021, 4:24 am
Interior wood.
Postby Midnightsun » May 10th, 2021, 4:58 am
Mine is advertised as Cherry. That being said, many older boats had solid wood, newer ones like mine have basically an ultra thin lamination obviously to cut costs however engineered wood does have an advantage when it comes to product stability. Do not know where or how big the area is you need to repair/replace but you could consider a wrap if the area is suitable visually. I did do this to my galley where everything in black you see is a wrap. The sharp edges on the drawers and cupboard did not look good at all. Beauty of a wrap is it is easily reversible back to original if one so choses.
Before and after pics.
tonyiiiafl
Postby tonyiiiafl » May 10th, 2021, 5:25 am
Looks great. I need an overlay of sorts. Drilled twice and measured only once installing a water level gauge. I have solid plywood with a veneer on top. I also though it was cherry. Thank you.
