Chattanooga area electrician needed!!
Topic author Netherlands
Kramer_cruising
Vessel Info: 1993 Carver 390 CPMY
Has thanked: 6 times
Postby Kramer_cruising » May 9th, 2021, 9:00 pm
Can anyone recommend a solid electrician in the Chattanooga area??
Thank you!
Re: Chattanooga area electrician needed!!
Postby Viper » May 9th, 2021, 10:39 pm
Can't help with that but what do you need done?
Postby g36 » May 10th, 2021, 11:35 am
See your other post
Postby Viper » May 10th, 2021, 12:25 pm
Would be nice to keep this in the Electrical section though.....
Along with g36's suggestion in the other thread, if you disconnect shore power and run the genny, will the breaker still trip? Main breakers do fail sometimes, they can seem okay until a load is applied.
Kramer_cruising
Postby Kramer_cruising » May 11th, 2021, 3:32 pm
Hi, thanks for your suggestion. I will try and run the generator instead of shore power and see what happens. Haven't tried that yet.
Kramer_cruising
Postby Kramer_cruising » May 11th, 2021, 3:38 pm
I am going to be on the boat in Soddy Daisy this coming Saturday, and I will try to run the generator instead of shore power to see what happens. If people are in the area and they can make themselves available to take an expert look at this issue, please let us know.
Return to “Electrical”
Users browsing this forum: waybomb and 14 guests
