C37 reviews...diesel mpg?
Topic author
nole1989
Postby nole1989 » July 13th, 2016, 7:08 am
Hello, the C37 is on my short list of boats that we are looking at. I cannot find any test results for the volvo diesel engines. the merc gas only get under 1 mpg. Also, if you own a C37 would love to hear real life pros and cons! Thx
John in Jersey
Re: C37 reviews...diesel mpg?
Postby John in Jersey » August 31st, 2018, 7:57 am
Top
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » September 1st, 2018, 7:35 am
Welcome aboard.
Are you talking coupe or flybridge? One I read was a coupe with Volvo D4-300s topped out at 29 knots and sweet spot at 22 knots but no fuel consumption data. Try looking through here:
https://www.google.ca/search?rlz=1C1FLDB_enCA594&ei=DneKW89QmOaPBJzOlJAE&q=carver+c37+tests&oq=carver+c37+tests&gs_l=psy-ab.3...5159.14932.0.15306.23.23.0.0.0.0.195.2019.1j14.15.0....0...1c.1.64.psy-ab..8.15.2017...0j0i22i30k1j0i67k1.0.Omu9_HPjAuk
Sgranier
Vessel Info: 2017 C37, Volvo Penta D4 300 EVC 3.7L Inboards, shafts
Postby Sgranier » April 7th, 2021, 10:41 am
Hi, did we ever get to the bottom of the D4 mpg on the C37? taking possession of mine next month and was wondering.
Sebastien
“Mona Lisa” 2017 C37, Volvo Penta D4 inboards, shafts
Flyboy2000
Vessel Info: 2019 Carver C36
Postby Flyboy2000 » May 8th, 2021, 12:03 pm
Hello,
Any data Yet?
I also would be curious...
-Lee
C36 w/ VolvoD4 one week or less away!!
Been thanked: 601 times
Postby tomschauer » May 9th, 2021, 10:29 pm
When you get into boats over 30', its not usually, miles per gallon, its gallons per mile at cruise speed.
Been thanked: 1180 times
Postby Midnightsun » May 10th, 2021, 5:24 am
All engines consume the same no matter how big or how small the boat they are installed on at any given rpm, more or less. That being said, a D4 300hp will consume about 12 gph/engine at 3200-3300 rpm which will be the normal operating rpm while up on plane. Just need to know at what speed this boat will run at that rpm to calculate mpg. We can assume you will be doing more than 24mph (24 gph total burn) so you will definitely be over 1 MPG, my guess will be closer to 1.5 mpg. At hull speed I will guess you will be running about 1250 rpm which will substantially reduce the burn to about 2 gph or less per engine, once again we need to know the speed at which the boat will be travelling but I can tell you will go quite the distance compared to on plane as this is where a diesel shines.
https://www.boat-fuel-economy.com/volvo ... us-gallons
Sgranier
Postby Sgranier » July 13th, 2021, 3:21 pm
Hi Everyone,
Just picked up my "new to me" 2017 C37 in Michigan last month, Diesel, 100 hours, and did 1,000NM on the Volvo D4's (with reverse-drive shafts) all the way to NJ.
sweet spot Cruise speed at 80% power 3,000 RPMs, 23KTS, average 1.2MPG to 1.3MPG in calm seas
WOT 29.3KTS+, 3,650RPMs, 31GPH.
hope this helps,
Sad for Carver going out of business. absolutely love the boat.
Sebastien
