"But I've Been Doing It That Way For Years...."
- Has thanked: 469 times
- Been thanked: 1765 times
- Been thanked: 1180 times
Re: "But I've Been Doing It That Way For Years...."
- Has thanked: 598 times
- Been thanked: 1281 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
2022 Stingray 182 SC
Not a chance. I've been through that with people before when they ask what I can do to help them make a claim. It's not an accident, it's ignorance. You can try though!bud37 wrote:Source of the post Wonder if insurance will take care of that......
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
Sort of helps me sleep at night... not really.
- Been thanked: 601 times
Somehow, he was lucky enough not to crack a block. Go figure.
RGrew176 wrote:Source of the post This is exactly why I always leave winterizing my engines to a professional. They screw up they fix. I'm not saying I couldn't do it but I sleep better at night knowing it was"hopefully" done properly.
My first adventure into an inboard pocket cruiser. Did not know much at the time. Had a marina take care of my winter storage. Launched the boat in spring however started having over heat problems above 3500 rpm or so. Turns out both heads were cracked on my Mercruiser 5.0!. Marina refused to admit it was their mistake. Cost me a lot of $ to have it fixed. This was the beginning of my learning the ropes and DIY. A different Marina on another boat broke my water tank inlet which once again was not their fault, it was very obvious what had occurred. Had to cut the floor out to change the tank! Since then nobody but myself works on my boat with some rare exceptions.
Maybe I had bad luck but too many times have I seen shoddy work or incomplete assembly. Every spring I count the cars on the side of the road that lost a wheel after winter tire to summer tire change over. This year it was only 3 and those are only the ones I saw. Somebody forgot to tighten the bolts on a wheel!
Not saying all professionals are not good however when you find one, hang on to him because they are worth their weight in gold. I have a guy called Tony, he is great and actually did all the work 2 years ago when I ran aground. He definitely is a keeper and worth his weight in gold.
- pepmyster
8.1 Volvo Penta
- Has thanked: 487 times
- Been thanked: 206 times
