Need to repair or replace DC Amps meter
- BarryK
- Vessel Info: 1990 Santego 3467
Twin 454 Crusaders - Location: Oxnard, CA
- Has thanked: 12 times
- Been thanked: 6 times
The DC amps meter on my panel is not working, the needle stays fixed in position at about 30 amps. How to I open the panel to remove the gauge? Where can I buy a replacement?
Thanks,
Barry
- Been thanked: 646 times
Re: Need to repair or replace DC Amps meter
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
Unplug from shore power and turn off your batteries first.
- Has thanked: 469 times
- Been thanked: 1765 times
https://www.amazon.com/Analog-Panel-Meter-Current-Ammeter/dp/B00A4TQY02/ref=sr_1_6?dchild=1&keywords=dc+panel+amp+meter&qid=1620992322&sr=8-6
There's also digital units that give you some other useful information. I'm replacing all of my analog meters with digital ones. Some AC ones for example give you hertz which is good to know especially when you're running your generator or you suspect there's a marina or utility problem.
- Has thanked: 598 times
- Been thanked: 1281 times
- BarryK
Thanks again.
Users browsing this forum: Majestic-12 [Bot] and 9 guests
