Automatic Halon Replacement question Kidde Mariner Fyre Watch Model 170 Halon 1211
tricountytrail
Vessel Info: 1989 Carver 2557 twin 180/3.7LX Alpha One drives
Postby tricountytrail » May 16th, 2021, 11:39 am
Looking to get this replaced or upgraded any thoughts or ideas?
It is about as big as regular fire extinguisher mounted in a regular mount on bulkhead.
It reads zero pressure and needs to be replaced or recharged.
Thanks for any help.
Has thanked: 78 times
Been thanked: 1093 times
Re: Automatic Halon Replacement question Kidde Mariner Fyre Watch Model 170 Halon 1211
Postby km1125 » May 16th, 2021, 11:53 am
You can check with any good local fire extinguisher outfit to see what they charge for checking it out and recharging it. Might be less expensive than a new one and would work just as well (provided it is large enough for the space it is supposed to protect).
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » May 16th, 2021, 8:45 pm
I don't think they'll recharge with Halon again.
Postby km1125 » May 17th, 2021, 8:55 am
Viper wrote:Source of the post I don't think they'll recharge with Halon again.
You can't buy new, but you can have existing systems serviced and refilled. At least on this side of the border.
tricountytrail
Postby tricountytrail » May 17th, 2021, 9:59 am
I've been calling around and can't find anyone that will refill. Still looking Buffalo area.
Postby km1125 » May 17th, 2021, 1:33 pm
This place is in Lancaster and on their site it says they do hydro testing and halon refills, but I have no specific knowledge about them:
https://www.trostfire.com/
Been thanked: 601 times
Postby tomschauer » May 17th, 2021, 10:29 pm
You can get an extinguisher refilled with reclaimed Halon. But you can probably get a new FM or cg2 bottle cheaper. Also, if its empty and didn't discharge, there is a problem with the existing bottle and mechanism.
