City water pressure
- pepmyster
8.1 Volvo Penta
- Has thanked: 487 times
- Been thanked: 206 times
Re: City water pressure
- Has thanked: 469 times
- Been thanked: 1765 times
- pepmyster
8.1 Volvo Penta
- Been thanked: 601 times
- Been thanked: 1180 times
- RussL
- Vessel Info: 2000 396 Motor Yacht
- Has thanked: 18 times
- Been thanked: 11 times
- RussL
Most likely the inlet has a check valve / Water pressure reducer either in it or directly behind it. This type is common and they are build in. (https://cdn11.bigcommerce.com/s-6rtev5owwo/images/stencil/1280x1280/products/235007/125853/183-029-18__20928.1581002960.jpg?c=2) They can get stuck or damaged from freeze if there is still water sitting in them.
I also know someone who installed a water filter directly behind their inlet. It froze and split wide open... I assume you don't hear water or bilge alarms?
Viper wrote:Source of the post Hans, that's the same spec as most dockside inlets with built-in regulators. Most are anywhere from 45 to 65 psi depending on the model. Some units were actually serviceable, but I don't know if any are still made that way.
I had a Shurflo brand from the factory so I swapped it out for the same unit. Pressure was once again inadequate, same as before. Threw out an $80 new part and replaced with outboard regulator and non regulated inlet, problem solved. My best guess it the pressure I got out of the Shurflo unit was less than 35psi on a good day. https://www.westmarine.com/buy/shurflo- ... et--183725
Bought a stainless steel regulator thinking go with the best. Plugged it into the hose at the dock and nothing came out but a small trickle. They sure do not make things like they used to!
- Been thanked: 646 times
