Blowers not working.
- bobcinga
- Vessel Info: 2006 CMY 41
- Been thanked: 4 times
Problem - tried to turn fans on. All four breaker switch’s on, main power for dc panel on, instrument panel switch turned on. Fire extinguisher light comes on, light in instrument switch on- nothing from blowers.
Tried with switch on dc panel in salon- no light on switch and no blowers
Read in forum about blower #1 must be on, so tried, nothing, then #2. It ran! Three-nothing. Four-nothing
Started engines. Usually light on instrument switch comes on when engines are on. Blower still ran but no,light
Turned off engine and blower switch #1 & #2. Tried to turn blower on again, nothing, tried all sorts of combinations - nothing. Thought a relay might have overheated, so waited a while- nothing.
So, I’m sure I have power at main dc panel on switch. (Horns and everything else works) Pretty sure I have power at four blower switches, (a blower ran) at least in the first one because light comes on in instrument panel switch. Pretty sure in at least the manual on position I have power at the instrument panel switch.
I don’t think all four blowers would die at once. And # 2 blower worked at least for a little while. The light for the blower switch in the main dc panel does not come on in any configuration.
I’ve read about relays in these forums. Are they next to the blower motors in the bilge?
My first mate and I are 95% sure when we got back to the dock, yesterday, no blowers were on. I don’t recall turning them off. They are usually so loud you can’t forget to turn them off. I did run them for four minutes prior to departing and all was fine.
Thoughts?
Re: Blowers not working.
- bobcinga
- Has thanked: 603 times
, maybe a cracked/broken connection. Happened to a few of us.Do you have the wiring schematic in your owner's guide ?
- bobcinga
I had a tech at our marina look at it. He tapped on one blower and it started up, so may be just a bad blowers. Will let board know when we figure it out
- bobcinga
Solution was to replace all four blowers, relays were fine. All good now.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Greg
- kwkirkwood
- Vessel Info: 2012 Carver 41 CMY
- Has thanked: 1 time
The blowers spin freely when spun by hand and look pristine. I haven’t wanted to clip the wires to put a meter on them because reattaching will be difficult in that space. I’ll also add that the wires leading up to each fan are large gauge wires (brown with yellow stripe and yellow) and there are no large gauge wires exiting the Fireboy (under the dash on the helm) which is leading me to believe that there is another relay somewhere that over been unable to locate. I’ll take any thoughts, ideas, or hints but I’m mainly looking for that relay.
