Gas Grill
- HudsonRiver01
- Vessel Info: 1990 Carver Santego 38
- Has thanked: 14 times
Gas Grill
Re: Gas Grill
I used to use a small 5lb bottle and did the same you want to do with the hose shown above, still have it but went back to the 1lb bottles.
- Has thanked: 474 times
Re: Gas Grill
I would get the hose Hans mentioned above, you want to use the regulator that came with the grill, that way you know it's the right spec for that unit.HudsonRiver01 wrote:Source of the post ...can I just purchase a propane grill set up with regulator....
- HudsonRiver01
Re: Gas Grill
Midnightsun wrote:Source of the post It will work fine however you will need to purchase the adapter hose to connect the home depot bottle to the regulator of the Kuuma grill which has threads for a small 1 lb bottle. Like this. https://www.canadiantire.ca/en/pdp/mast ... 1097p.html
Viper wrote:
Source of the postI would get the hose Hans mentioned above, you want to use the regulator that came with the grill, that way you know it's the right spec for that unit.HudsonRiver01 wrote:Source of the post ...can I just purchase a propane grill set up with regulator....
Thank you both for the advice. Steaks will be ready soon
actually I think Striper will be the first meal. We just have a couple in the freezer from this week.-
Re: Gas Grill
