Water in bilge when I turn on ac
Re: Water in bilge when I turn on ac
I don’t need to turn on units for bilge to fill, just the pump.
Like Viper said, you should not be able to turn on the pump. It only turns on if you turn on any AC unit.
- Has thanked: 602 times
- Been thanked: 490 times
You need to follow the line from the pump to all three ac units, and then from the ac units to their through hulls. It should be coming out
the exhaust channel;
midships, port side;
and bow end which side, I don't remember.
If you have it flowing from the exhaust and the bow, I'd start with the one in the middle. Climb into the engine room, forward of the genset, and I believe you'll see the discharge hose of the mid-ac unity. It's probably busted or disconnected from the through hull.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
pdragula wrote:Source of the post I don’t need to turn on units for bilge to fill, just the pump.
Ok, humor me on this question...
I assume you are turning on the pump at the circuit breaker, correct?
If so, are you turning on the circuit breaker on the 120 volt side of your electric panel or the 12 volt side?
- buster53
pdragula wrote:Source of the post Hey guys,
Yes I have traced all lines and no leaks. I don’t see how it is connected to exhaust. Water is discharging from exhaust, front of hull and now bilge.
Anyone know where to look for connection on exhaust from ac?
Ok, what’s the latest....
- vtcats
- Vessel Info: 2006 46 Voyager
Volvo D9-500’s - Location: Burlington VT
- Has thanked: 2 times
- Been thanked: 5 times
Mallets Bay, VT
