erWelcome to Carver Yachts Owners Forum
Run Dry Impellers
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Run Dry Impellers
- Cooler
- Has thanked: 602 times
- Been thanked: 1310 times
Cooler wrote:Source of the post Yes. The thing the is weird is if I have double the water volume coming out of exhaust at idle, would that not mean more water available to cooling system? What do you think about running at 170 degrees?er
Good idea IMO......The warmer you can get those engines/cylinder heads to run at the more efficient they will be all around. This applies to you cause you are in fresh water, but it still has to be kept within reason.....good luck.
I have a question though, in any of the material you read about these impellers, was there any mention of flow vs rpm graphs or comparisons ?
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
by the way: if you do see damage to the impeller; go search for the remnants!
Salt water applications differ since there is more harm done due to salt crystallization within the cooling passages at higher temps and it is advisable to run 140f thermostats in this application.
Found this article that explains it better than I do. https://www.oceannavigator.com/saltwate ... -clogging/
- Been thanked: 1111 times
Also don't understand the temperature change. If it's raw water cooled and there's MORE water coming out the back that means there's MORE water that could be going through the engine, but the thermostat is opting for it not to go through the engine because it's staying more closed. Is it possible just the thermostat housing is staying cooler and "tricking" the thermostat to think the engine water is cooler than it really is? Where is the gauge temp sensor located relative to the thermostat?
- Cooler
