Sea Star Steering question
- RussL
- Vessel Info: 2000 396 Motor Yacht
- Has thanked: 18 times
- Been thanked: 11 times
My 2000 396 has dual SeaStar tilt wheel helms, but I am not sure of the model. Last weekend the upper help became more difficult to turn and it stick a bit at about 20 degrees left or right of center. You can turn though the hard spot and then the pressure releases suddenly and you can turn again more normally. It does this same thing a to a lessor degree in a couple of other spots. The lower helm is what I would consider a bit stiff as well but doesn't stick. Also, I have had the boat less than a year don't ever use that station, so I can't say if that is normal or not... I admit I don't know a lot about hydraulics, so I am hoping some can help. Does this sound like air or some failure of the helm?
Thanks,
Russ
- Has thanked: 474 times
Re: Sea Star Steering question
- RussL
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Turn the wheel from left to right and back a few times and it will smooth out.
Greg
- RussL
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
