Cover for electrical and water shore connection
tgebler
Vessel Info: 2000 396 AC
Has thanked: 5 times
Been thanked: 29 times
Postby tgebler » June 10th, 2021, 11:51 am
My 2000 396 aft cabin has a small door on the transom which covers the access for the shore power and shore water connections. The door is broken which I would like to replace. Any suggestions? Thanks.
tgebler
Re: Cover for electrical and water shore connection
Postby tgebler » June 10th, 2021, 12:10 pm
https://i.postimg.cc/3RXYzmr9/Electrical-box.jpg
The cover is shown in the photo.
vineyardgray
Has thanked: 128 times
Been thanked: 33 times
Postby vineyardgray » June 10th, 2021, 12:17 pm
You have power and water in the same enclosure?
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
tgebler
Postby tgebler » June 10th, 2021, 12:21 pm
That is the way Carver made it but yes. I am talking about the shore connections.
Postby Midnightsun » June 10th, 2021, 3:27 pm
vineyardgray wrote:Source of the post You have power and water in the same enclosure?
Same on my boat. Although no door just an access hole. Image
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » June 10th, 2021, 4:20 pm
vineyardgray wrote:You have power and water in the same enclosure?
Agree, that is a bad design. Thankfully, on my 356, I have my shore power connections in a compartment with a door and my water connection is on the other side of the transom.
Got a buddy with a 41’ Regal and he has both connections in an enclosed compartment. Can’t believe ABYC would allow that. Maybe they did at one time but don’t any longer.
tgebler
Postby tgebler » June 10th, 2021, 4:39 pm
Ok, bad design but where do I get a replacement door?
Has thanked: 474 times
Postby Viper » June 10th, 2021, 9:12 pm
Doubtful that their still available but it doesn't hurt to try and call Carver with your hull number. I would just get some 1/2" starboard, cut it out to shape, attach the hinges and away you go. Lots of other plastic options available too.
Postby km1125 » June 11th, 2021, 10:48 am
might also try greatlakesskipper to see what they might have.
What's actually "broke" with the current door? Is it a hinge problem or a latch problem or is the door actually fractured somehow? If the door is actually broke, maybe a local glass shop could use the parts to make a mold and create a new door our of GRP?
RussL
Vessel Info: 2000 396 Motor Yacht
Has thanked: 18 times
Been thanked: 11 times
Postby RussL » June 11th, 2021, 11:16 am
tgebler wrote:https://i.postimg.cc/3RXYzmr9/Electrical-box.jpg
That is my boat :)
Do you have the cover at all or is it missing? I am going up to my boat next weekend and I would take some measurements for you. It is just a piece of 1/4 plastic that has been cut to fit. I would order some from amazon, Tap Plastics, or where ever else (Make sure that the type you buy is UV resistant and will be ok in the elements). Then just cut it out with a jigsaw and a metal cutting blade.
To be honest the box is kind of a pain and I have thought about taking it out all together. ad putting a blank over it with exterior grade connectors.
Could you take a picture of yours and post it? I am going to add a shore water connection and I have had a hard time finding a picture of where the factory connection is located exactly.
