idle issue
- megbert
- Vessel Info: 1997 Voyager320 - purchased in 10/15
idle issue
thoughts?
- Been thanked: 1110 times
Re: idle issue
Easy enough to check. Pull the caps off the distributors and use your hand to manually advance the rotor. You should be twisting against a spring and it should snap back. You could also check with a timing light by revving the engine while watching the advance go up and down.
how did you work around the issue when it happened at the fuel dock?
Re: idle issue
- megbert
Re: idle issue
What are thoughts on idle control valve or throttle position sensor?
Re: idle issue
This is where the engine model helps. The good thing is that you have two engines and can swap one part at a time and see if the problem follows the part.megbert wrote:Source of the post.... What are thoughts on idle control valve or throttle position sensor?
- stanboyd89
- Vessel Info: 1986 Carver 4207
Re: idle issue
- stanboyd89
Re: idle issue
- Been thanked: 653 times
Re: idle issue
- SeattleMatt
- Vessel Info: 1995 Carver 320 Voyager
Twin Crusader 350XLHT - Location: Seattle
- Has thanked: 12 times
Re: idle issue
- mjk1040
- Been thanked: 248 times
Re: idle issue
Users browsing this forum: No registered users and 51 guests
