Volvo QS BP1200 bow thruster replacement
Re: Volvo QS BP1200 bow thruster replacement
Postby Viper » June 23rd, 2021, 8:56 pm
The QLs have an oil reservoir so any pressure would send oil back up the feed line. It's not an appreciable amount though but when that happens, it either goes up the line or out through a leak. Depending on the leak, when going up the line, the volume it displaces has to be replaced by something else...water if it can. In a sense, at that spot, it'll create a vacuum and bring water in. For that reason, some sterndrives require both a pressure test and a vacuum test to ensure the seals are working both ways. The difference with a lower unit is way higher rpm, pressure, and temperature, not nearly the same conditions as a thruster leg operation.
I started thinking about all the sources of how petroleum products make their way into the waterways on boats. Taking measures to eliminate as much of that as possible is a good thing whether at the manufacturing or ownership level. Techs can make a huge difference here too. Don't know how many times I see techs greasing all the points on a sterndrive and not even bother to clean the excess grease off the grease nipple. Marinas can play a huge roll too. All too often I see marinas launching boats where the trim tab actuators are clearly leaking, that should be an automatic no launch until it's fixed. It may seem like a small amount but add that up for all the sterndrives, trim tab actuators, etc. out there...it all adds up. Sterndrives are the worst, there's so much grease in the water with them. Heaven forbid you have a bad enough impact to break the lower unit and spill it's entire contents of gear lube. You know, they push marinas to use vegetable based oils and greases for their equipment working around the water but there's nothing said about what gets used in vessel hardware actually running and sitting in water all the time. Having said that, I think it's just a matter of time before that changes.
dtlag
Vessel Info: 1999 Carver 406 Aft Cabin Motor Yacht
Has thanked: 2 times
Postby dtlag » September 1st, 2021, 9:45 am
Good morning,
Just wanted to check to see if anyone had found a good source for parts for these or a suitable replacement?
Thank you!!
Royb
Vessel Info: Carver 530 Voyager
Been thanked: 5 times
Postby Royb » December 1st, 2021, 9:17 am
I have attached a photo of all the bearings for this unit.
Royb
Postby Royb » December 1st, 2021, 9:19 am
There are two shaft seals (both the same), are metric and easily replaced for around $5 a piece. The number is stamped on the side of the seal.
eburklo
Vessel Info: 2003 Carver 564
Postby eburklo » August 13th, 2022, 11:13 am
I guess I got lucky. The water was leaking thru the plug on the gear case. We had the boat pulled and dropped the gear case. Soaked the gear case in brake fluid cleaner for days. Replaced the plug and the zinc which screws into the plug and reinstalled. Now been a year and works fine.
Joemo4454
Vessel Info: Marine/ bow thruster tech
Postby Joemo4454 » February 11th, 2023, 2:51 pm
Regarding a replacement for Volvo bp 1200. I am joe molinaro owner of east coast bow thrusters. We do many of these swap outs per year. As mentioned in a previous post the side power se 130 is very marginal for the 56 carver my. We always use the vetus bow 160. This is the comparable thrust as the Volvo unit and fits the 250 mm tunnel. We utilize existing batteries and supply wiring to feed the thruster and glass over the old holes and run new control circuits and new vetus joy stick. The utilization of some existing keys costs reasonable. Feel free to contact me for questions or quote. Ecbowthrusters.com
Sweden
andbro
Vessel Info: I have a Colin Archer 47 traditional sailing rescue vessel. I know this is ver far from a Carver, but found a thread discussing Volvo’s QL BP1200 and how to source parts for the gearbox. Esp a post by Royb in Dec 2021 with pictures showing part numbers for bearings and gears would be very valuable. Also would to ask the members is someone know if the gears can be bought off the shelf from manufacturer and if someone knows the angles with which the gears meet inside the gearbox.
Postby andbro » June 22nd, 2023, 6:46 am
Hi All,
and thank you for a lot of very valuable information about the BP1200. Esp. thank you to Royb for posting the info and picture with the bearings - super valuable!
One thing which remains for me to repair my thruster is the broken gears - the teeth are all basically sheared off.
Does anyone know if these were standard off the shelf as well or if not, does anyone have the design specs or can measure the outer height of the teeth and the angle of the upper outer corner of the teeth towards the centre? Knowing this it would be possible to source gears off the shelf or worst case manufacture new ones. Would be happy to place an order for several if anyone is interested.
gmcsteam
Postby gmcsteam » April 15th, 2024, 6:58 pm
Just ordered a set of Gears, Bearings and Seals for the QL BP1200 from Thrusterparts.com.
ck36
Vessel Info: 2002 Carver 450 Voyager, TAMD74P
Has thanked: 17 times
Been thanked: 4 times
Postby ck36 » July 2nd, 2025, 2:20 pm
gmcsteam wrote:Just ordered a set of Gears, Bearings and Seals for the QL BP1200 from Thrusterparts.com.
I'm looking at the same issue with a Carver 450 Voyager that I just took ownership of. Would you be willing to share your experience with how the changeout of components went for you?
eburklo
Postby eburklo » September 2nd, 2025, 6:03 pm
My 2003 Carver 564 had a similar problem. I was able to purchase a new plug for the gear box. First we removed the gear box and soaked it in brake cleaning fluid for over a week. Then replaced the plug and reinstalled the gear box. Knock on wood, seems to be working fine. The real issue here is the plug just wears out. If you can find one, buy a 2nd.
