Battery Problem
Battery Problem
A little info. Dual 435AH 6V L16 batteries, secondary charger is only 10a per bank and seems to charge but at a ridiculously slow rate. This charger is hooked up directly to the battery so no acr or isolator to go through. Water levels on both batteries are fine and a visual inspection shows plates clean as a whistle.
Bottom line is the bank just seems like it does not want to take a charge at a normal pace.
Anyone have any advice/suggestions for me before I dish out a bunch of boat dollars and lug 125lb batteries around?
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Battery Problem
Sometimes batteries just short out or die with no obvious reason. With only two years they would have some warranty I think.
The other thought , the charger is not recognizing the battery or is bad....past that I don't know, you will have to do some exploring, chargers, isolator etc.
Re: Battery Problem
Re: Battery Problem
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Battery Problem
Re: Battery Problem
Re: Battery Problem
Midnightsun wrote:Source of the post Just checked it again remotely, went from 12.98 to 12.04 with a smaller 10a charger connected directly to the house bank
That would be quite a load to pull down to 12.04 on a good battery, have you checked this with a good multimeter directly on the bank....What was your float voltage for that bank before ?
Edit....to add, a good battery monitor with a shunt would alert you to any parasitic loads that may not be obvious otherwise....
- Been thanked: 1111 times
Re: Battery Problem
With that charger and a significantly depleted battery bank, it would probably take 40 hours to get them fully charged, and that is with *no* other load on that circuit.
Re: Battery Problem
Re: Battery Problem
