Prop shaft zincs
Roddono
Vessel Info: 1991 Carver 33 Aft Cabin
Has thanked: 26 times
Prop shaft zincs
Postby Roddono » July 8th, 2021, 3:14 pm
Hello,
I have a 1991 Carver 33 aft cabin with twin 454’s. My diver can not find the correct shaft zinc diameter to replace them. He is starting to wonder if it is metric. Does nobody have an idea? He said it lies somewhere between the normal sizes of 1 1/8-1 1/2.
Any help would be appreciated.
Ray…
Been thanked: 1310 times
Re: Prop shaft zincs
Postby bud37 » July 8th, 2021, 6:17 pm
Go down in the engine room and measure the shafts with calipers, that will give you the exact shaft size....my guess , they are not metric.
Been thanked: 1111 times
Postby km1125 » July 8th, 2021, 10:29 pm
1 3/8 was a popular size, but definitely check as bud37 says.
Postby Midnightsun » July 9th, 2021, 6:07 am
I seriously doubt it is metric coming from Carver. That being said measuring is the best way but as mentioned 1 3/8 does fall between the measurements you mentioned. Regardless of what he size may be, this place will have it. https://boatzincs.com/
Petemait
Vessel Info: 1983 Carver Riviera
Has thanked: 56 times
Been thanked: 18 times
Postby Petemait » July 9th, 2021, 9:02 am
Probably 1 1/4. My single engine gas a 1 3/8" shaft and i know the book says that the option with two engines has two 1 1/4 shafts. My boat is a 2807 Riviera but your boat may have been built the same?
Good luck- checking in the engine room/area to confirm is a good call.
Pete
1983 Riviera 2807
Boston, MA
Postby tomschauer » July 10th, 2021, 12:35 am
.my 1998 355 has 1 3/8 shafts.
They are not metric.
plittle2005
Vessel Info: 1992 Carver 350 Aft Cabin
Has thanked: 16 times
Been thanked: 37 times
Postby plittle2005 » July 22nd, 2021, 9:25 pm
My 1992 350 Aft Cabin has 1 3/8" dia. shafts. Not Metric.
Users browsing this forum: Google Adsense [Bot] and 13 guests
