Galley Bilge
schulte54
Vessel Info: 1999 Carver 356 my
Galley Bilge
Postby schulte54 » July 19th, 2021, 3:43 pm
Front Bilge Pump (Galley) I found with a hose off and water in the dipped lower area under the galley floor panel. The pump works, but water sits below it or is that small black hose supposed to be there to suck up that little bit of water and the hose just became detached?
Re: Galley Bilge
Postby Viper » July 19th, 2021, 10:11 pm
Would have to see a picture of your setup but if it's a typical bilge pump, you'll always have a little water left as the pump doesn't get it all.
Wsullivan71
Vessel Info: 2001 Carver 404 Motor Yacht
Been thanked: 12 times
Re: Galley Bilge
Postby Wsullivan71 » July 22nd, 2021, 1:22 pm
I've just started to have the same problem and I am thinking it is the condensate drain from the salon AC unit. It appears to drain into that area and the bilge pump can't get it all out.
Liechtenstein
chpsk8
Has thanked: 27 times
Been thanked: 76 times
Re: Galley Bilge
Postby chpsk8 » July 23rd, 2021, 11:52 am
My front bilge is similar. The pump and float sit on a ledge which means I can’t get the last three inches of water out of it. Some days I get water in there, others I don’t. No pattern that I can figure out. DrIves me crazy.
I have a small sump pump I throw in there every once in awhile and suck it all out and drain it into the sink. Keeps the smells down.
