Refrigerator Not Cooling Good
- Rocketman
- Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
- Been thanked: 24 times
Freezer holds at about 20 degrees. This is not cold enough to keep ice-cream frozen.
Fridge holds at about 35 degrees on the top shelf right next to the cooling plate.
Lower shelf is at 40 degrees or more.
These temps are after overnight of not opening the unit.
During the day while using the fridge will get up to 40-45 degrees on the top shelf.
Ice takes a good 12 hours to freeze if not longer.
Cabin temps are below 70 when running the A/C and about 80 to 85 max before we start cooling it back off.
Good ventilation around the unit.
I have checked the coils and they are good and clean.
Does not seem to matter if on AC or DC power.
Thermostat set to max. Has new thermostat as I thought maybe that was the problem.
I am wanting to replace with a new unit that will work more like a home fridge (close to 0 in freezer and hold 35 everywhere in the fridge). Thinking about the Vitrifrigo as they seem to have the best reviews.
Thoughts?
- Been thanked: 654 times
Re: Refrigerator Not Cooling Good
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
- Been thanked: 1111 times
And definitely check those door seals as RobGunn says. Just a TINY leak in the freezer section can make a HUGE difference!
- Rocketman
Frost - not to the point that it needs defrosting yet.
G36 - does your virtifrigo seem to be consist temps throughout or is it warmer at the bottom of the fridge?
Do they have a cirulation fan inside the fridge to maintain constant temps?
The NovaKool does not and I think that is one of the problems. When it gets cold enough up top - the bottom is still warm for a fridge.
- Rocketman
I tried putting a battery fan in the fridge for a while but it really did not help much.
Midnightsun - I will try giving Novakool a call.
- uchu
- Vessel Info: 1988 Carver Santego 2767 - Twin Mercruisers 4.3LX with Alpha-One drives
- Has thanked: 86 times
- Been thanked: 15 times
RobGunn wrote:Source of the post Is the freezer all full of frost? I just had issues with my Norcold fridge due to the door seals not sealing and letting the freezer get all forested up and then caused warm temperature issues. New door seals and a total unit defrost and now I am back in business.
+1 on this. My almost-vintage motorhome has its original Norcold unit and a while ago developed issues which were solved by changing the door seals. Also, I noticed that a good "reboot" (turning the unit off and waiting about 24h before turning it on again) worked to get it fully functional again.
- Rocketman
I went ahead and defrosted (even thought it did not need it).
Temp at the very back top shelf is holding at 35 degrees. 2nd shelf is at 40 and 3rd shelf is at 45.
And that was with not a lot of stuff in there (some drinks and a 1/2 gallon of milk laid on its side at the back).
Freezer is holding at about 10 degrees and takes ice about 12 hours to freeze.
Thermostat is on 7 (max).
No air flow or any moisture around seals so no leak there.
I am thinking the compressor is starting to go out and it is just not cooling good enough. Even though compressor sounds fine it is running 100% of the time.
