Swim Platform
bipper1952
Vessel Info: 1995 Carver 390 MY
Swim Platform
Postby bipper1952 » July 26th, 2021, 1:54 pm
We have a 1995 Carver 390MY that is new to us and we would like to remove the swim platform from this boat in the fall and rebuild and/or have it modified over the winter or just add new. Is it thru bolted does anyone know or can we remove just the platform from outside. Can anyone give us advice regarding this?
Re: Swim Platform
Postby tomschauer » July 26th, 2021, 2:19 pm
I would bet $ there are nuts inside that you need to get a wrench on.
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Re: Swim Platform
Postby Tireless » July 26th, 2021, 8:41 pm
I guess it depends on what you want to do with the existing swim platform. If you want to re-core it you remove the upper or lower fibreglass skin and re-core it. If you want to make it bigger you don’t have to remove it.
I had a 40” extension put on my 356 but the dealer when I purchased it. It was expensive, but very much worth it.
Greg
Re: Swim Platform
Postby tomschauer » July 26th, 2021, 9:52 pm
Greg, your 356 has a platform molded as part of the hull. Its not a bolt on like the older models. You really cant add on to them and have any structural integrity.
bipper1952
Re: Swim Platform
Postby bipper1952 » July 27th, 2021, 2:14 pm
We are hoping to be able to remove it and fix or modify it and then re install it. It has a soft spot which needs to be addressed and we are hoping to be able to do that over the winter.
Gbb355
Vessel Info: 1995 355 aft
Re: Swim Platform
Postby Gbb355 » April 11th, 2022, 12:27 am
bipper1952 wrote:Source of the post We are hoping to be able to remove it and fix or modify it and then re install it. It has a soft spot which needs to be addressed and we are hoping to be able to do that over the winter.
What did you guys do about this? Mine has a soft area. Almost like there is no real support under in one particular area. Love to know how you resolved the concern
theorifice
Vessel Info: 1987 Carver Santego 30
Has thanked: 16 times
Been thanked: 4 times
Re: Swim Platform
Postby theorifice » August 22nd, 2022, 11:06 am
Likewise with regards to the soft spot. The starboar side of our swim platform on the 1988 Santego 30 feels much softer than the portside. Would love to get this resolved in the offseason.
What would be involved? It does look like a molded swim platform as well.
Fun times on the 1988 Carver Santego 30
