New member
- carverdjd233
- Vessel Info: 1984 Carver Santa Cruz Flybridge 2667
New member
It has no hot water heater??
Where can I find one to purchase?
Are the heated by the engine as well as 120v.
I don't imagine by the 12v system
David Doubt
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: New member
When you say, “it has no water heater?” Do you mean you can’t find it, it’s not working, or it’s missing?
Some water heaters provide hot water using engine heat and 120v from either shore power or generator power, others only when you have 120v AC available.. I’ve yet to seen one that runs off 12v DC power.
“Escape Plan”
Murray, KY
- Has thanked: 64 times
- Been thanked: 481 times
Re: New member
- Has thanked: 468 times
- Been thanked: 1765 times
Re: New member
Like the guys above said. Any marine dealer would be able to supply one. If it's going in a gasoline engine bay, it needs to be marine rated/ignition proof. Also, if you buy other than a marine unit to mount outside the engine bay, you need to ensure the unit is compatible with typical marine system pressures so the pressure relief valve actually works in an emergency. Marine units take this into consideration and is something surveyors are now looking for because so many people have been replacing these valves with generic household units.
ColRon, there is a 12 volt heater on the market. Don't know why anyone would want to go that route but it's available.
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
Re: New member
2022 Stingray 182 SC
- Torsson
- Vessel Info: Carver 28 Voyager 1988 Twin 350 Crusaders
Re: New member
