Shower Faucet
Terra Nova
Vessel Info: 2002 Carver 410 Sports Sedan
Has thanked: 2 times
Shower Faucet
Postby Terra Nova » July 25th, 2021, 10:39 am
I have a 2002 410 Sport Sedan. The faucet in the Master Shower is leaking from the base. I have taken the faucet apart from the top and replaced the O Rings on the valves but it hasn't fixed the leak. The water shoots out between the base of the faucet and the counter top. I can't take the faucet out because its completely sealed within the counter top and there is no access underneath it? I would literally have to remove the entire top which is sealed and glued to the base. Does any body have a similar design and have any advice on how I can replace this faucet?
Terra Nova
Re: Shower Faucet
Postby Terra Nova » July 26th, 2021, 3:31 pm
Does anybody know who the manufacturer of the shower faucet on these models are? I can't find anything in the parts manual and there are no labels or markings on the faucet itself.
Been thanked: 601 times
Re: Shower Faucet
Postby tomschauer » July 26th, 2021, 10:08 pm
I don't know your boat, but usually there is some way to access darn near everything. What is on the other side of the shower wall?
Terra Nova
Re: Shower Faucet
Postby Terra Nova » July 30th, 2021, 3:30 pm
Its the guest bathroom and no access. There is small hatch under the sink but you can't reach the shower faucet. I would have to remove the sink and plumbing in the guest bathroom to see if I could get close. But that sink is counter sunk and I would also have to remove that counter top. So far no luck on a manufacturer either.
Has thanked: 467 times
Been thanked: 1759 times
Re: Shower Faucet
Postby Viper » August 1st, 2021, 10:11 am
Post a pic of the faucet.
Terra Nova
Re: Shower Faucet
Postby Terra Nova » August 1st, 2021, 7:59 pm
These are pictures of the cartridges and the shower faucet with the leak.
Re: Shower Faucet
Postby tomschauer » August 2nd, 2021, 4:35 pm
I think that's a POS Camco faucet used on many boats and campers (including mine). You can probably get a new one at Eastern Marine or many other places. If its leaking from under the base as you say, it most likely cracked at the bridge and cannot be repaired.
Terra Nova
Re: Shower Faucet
Postby Terra Nova » August 3rd, 2021, 8:59 am
Thanks really appreciate it. I would like to change the faucet out completely but I have no access. I likely have to take the entire counter top off to swap it out. Unless anybody else has a similar boat and has a suggestion?
Re: Shower Faucet
Postby Viper » August 3rd, 2021, 10:17 pm
I think the counter top is caulked in place and has to be removed to gain access to the bottom of the fixture.
Terra Nova
Re: Shower Faucet
Postby Terra Nova » August 23rd, 2021, 6:06 pm
Thanks - that is my guess as well. Looks like a winter project....
