To rebuild or replace???
Marcq
Vessel Info: !989 Carver Santego 30
Been thanked: 6 times
Re: To rebuild or replace???
Postby Marcq » May 11th, 2020, 11:21 pm
So what happened? Did you replaced?
Marc..
Been thanked: 470 times
Postby RGrew176 » May 12th, 2020, 9:55 am
Inquiring minds want to know. :-D
Petemait
Vessel Info: 1983 Carver Riviera
Has thanked: 56 times
Been thanked: 18 times
Postby Petemait » August 5th, 2021, 8:53 am
Speaking of repowering, we had some unfortunate news recently. Our Riviera has a 1983 CH 350 454 crusader.
I've spent a lot of money on her recently, and thought we had her in good working order finally. We went out to refuel and the engine started making all sorts of bad noises- banging and rattling. We picked up the closest mooring and called boat us for a tow back to our mooring.
Our mechanic said it sounded like a bad piston, and we also need the head gaskets replaced.
I really don't want to put more money into this almost 40 year old engine.
What do you recommend for a repower? Remanufactured for $3500ish, new replacement which is apparently very hard to find right now for $7000ish? Other ideas?
Luckily we did not spend a whole lot to buy the boat knowing it needed work and had an old engine, so we are trying to stay positive.
Thanks,
Pete
1983 Riviera 2807
Boston, MA
Been thanked: 1112 times
Postby km1125 » August 5th, 2021, 10:58 am
Petemait wrote:Speaking of repowering, we had some unfortunate news recently. Our Riviera has a 1983 CH 350 454 crusader.
Thanks,
I'd probably be leaning heavily to remanufactured, if you're going with a reputable company. Those engines were very basic, but very reliable.
Would you be replacing both, or just the bad one?
EDIT - Argh! you should probably start a new thread, or your responses will get confused with the OPs.
Petemait
Postby Petemait » August 6th, 2021, 11:48 am
Thanks KM. It is a single so just the one.
Pete
1983 Riviera 2807
Boston, MA
