1977 Carver Mariner 33'
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 4 times
So briefly...this boat sat since 2008. It was winterized and shrink wrapped by the marina so that is a plus. I prepped the boat for transport across WI on Monday however they got hit with another 4"-9" of snow. Uggg...
So I have new batteries in it but did try to turn it over yet. I examined the hull, looks ok but I think I will pull the screws out of the port trim tab, goop them with 3m 5200 and screw it back in b4 launch on Sat. Should be interesting. I will have my deck boat there in case it won't start and will purchase a additional bilge pump just in case.
I obviously have a lot to work on but my 1st question...
How do you get the shine back on this thing? Can you do that while it sits in the marina or will my new boat neighbors frown on this kind of thing? Should I drive it out in the lake to do it? Just curious, I never really had a slip b4 and I am not sure of the unspoken rules.
Thanks and I am sure I will have a billion more questions.
Steve
Steve
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 29 times
Re: 1977 Carver Mariner 33'
Working on your boat in the slip is fine, just be mindful of other peoples pride and joy next to you, as well as the peace and quite they may want. Waxing etc should be no problem, sanding teak, fiberglass, etc. can be a problem... you don't want to cover your neighbors boat in teak dust
I suggest offering them a cold beverage or two.
When you get to know them you con them into helping.
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
SeaDragon
- Seif911
- Captain
We went to get gas for the boat and engine #2 does not have enough gas to start. Engine #1 started spitting mass water out of the block. Looking closer I think the freeze plug rotted out, hard to see. We were very bummed...so close to actually moving the boat and no dice
We will take a new rubber plug and 5 gals of gas on our next run.
Steve
- Been thanked: 490 times
Hey, at least you got one of them running?
When are you going to post some pix?
- Seif911
- Captain
Steve
- Seif911
- Captain
Steve
- Seif911
- Captain
Steve
- Seif911
- Captain
Steve
- Seif911
- Captain
Steve
Users browsing this forum: KellyMoore, KyleR and 31 guests
