Hynautic 50 upper helm feels off - crunchy for lack of a better term
- denders
- Vessel Info: 1985 Carver 3607 Aft Cabin
- Has thanked: 2 times
- Been thanked: 24 times
Thanks in advance
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Hynautic 50 upper helm feels off - crunchy for lack of a better term
To replace the pump with a new one, you'll need Seastar:
1x HH5273-3 - 2.0 Cu.In Displacement - 3/4" Taper Shaft Helm
1x HA5418 - Back Mount Kit
1x HA5432 - Non-vent plug
3x HF6012 - -5 ORB Male x 1/4" Female NPT
You can get these individually through various retailers or you can go here, they sell it as a kit: https://www.seatechmarineproducts.com/hynautic-h-50-hydraulic-helm-pump-seastar-replacement-kit.html
- denders
Dismantling the unit isn't that hard to do, there's several YouTube videos on it. Do that first if you're handy, it may just have a lot of crud in there, and a seal kit is about $50 compared to $1000 for a new pump retrofit. There's still a lot of parts available for the Hynautic should it be a part that needs replacing. You could also hunt down a used unit from a boat salvage yard. Relieve the air pressure in the reservoir before disconnecting the lines to the helm. By the way, the fluid should be inspected, and replaced if needed. If the grinding is the result of worn metal components and there's metal particles in the oil as a result, it'll eventually ruin the other helm and the steering cylinder.
- Has thanked: 78 times
- Been thanked: 1093 times
I had to do that twice over ~20 years. I was expecting to have to replace the seals but they never leaked. That is not that hard of a job to do and you can get the seals from any good hydraulic shop. I think I posted the parts on here in a different thread.
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
Users browsing this forum: No registered users and 46 guests
