Use of dry gas
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
Use of dry gas
Thoughts about adding dry gas, and is so, how much? Our tanks hold 165 gals. each.
- Been thanked: 654 times
Re: Use of dry gas
- Has thanked: 602 times
Re: Use of dry gas
tgebler wrote:Source of the post We are able to buy gasoline on the street and fuel our boat at the transient dock.
What type of gasoline are you planning on buying on the street.......if it already has ethanol, the dry gas ( alcohol or etc ) additive will not be needed. Do you burn lots of fuel or does the fuel in your tanks sit for long periods ( let's say two or three months or more ) ??
Now whether this is a good idea is another discussion.
- tgebler
Re: Use of dry gas
Re: Use of dry gas
The issue I have with these additives is that some literally claim to "remove" water from fuel which is a misleading statement and a whole lot of hype IMO. They don't remove water, they bind with water resulting in tiny droplets that are much easier for the engine to burn/run on safely. If you have a big water problem in your tank, these additives won't solve your problem.
- tgebler
Re: Use of dry gas
