33ss 8.1 crusader engines fluctuating rpms HELP
- mrterry72@gmail.com
- Vessel Info: Carver 2006 35ss
- Has thanked: 2 times
Re: 33ss 8.1 crusader engines fluctuating rpms HELP
- Has thanked: 602 times
- Been thanked: 1310 times
- Been thanked: 490 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
One way to eliminate the vent as a possible problem…next time you run the boat, take off the fuel fill cap. If the engine all of a sudden starts running good, you have a blocked or partially blocked vent.
Vent is a possibility, but if you ran three hours before the problem, most likely not the vent.
Another possibility is a bunch of junk in the tank, clogging the inlet screens. If this is the case, if you shut down the engines for a half hour or so, then they run fine for awhile before acting up it could be tank crud.
I am sticking with bad gas.
- buster53
tomschauer wrote:I don't think its the anti syphon valve. you have one for each engine on each tank. The odds of them both failing at the same time are pretty slim.
Re-read the OP’s first post…he only had problems with the starboard tank. When he ran both engines on the port tank, no problems. Sounds very much like bad gas or anti siphon valve….or both.
