New member
Horatio
Vessel Info: 2003 Carver 396, 8.1 Crusaders
New member
Postby Horatio » September 12th, 2021, 9:44 pm
Hello all, purchased a Carver 396 with 8.1 Crusader engines. So far, replaced control head (starboard engine idle only). Replaced relay board, Kohler generator, turned over when fuse installed. Soaked generator heat exchanger in Barnacle Buster and installed anode. Replaced plugs, soaked cylinders in mystery oil, squealed like a banshee when started, wrong impeller installed. Generator purrs like a kitten now. Tackling salon air conditioner tripping breaker now. Looking for Carver recommended blocking or cradle build instructions.
Been thanked: 470 times
Re: New member
Postby RGrew176 » September 13th, 2021, 2:26 am
Welcome Aboard. Hang in there. Someone will be able to answer your questions. Lots of knowledgeable people here.
Re: New member
Postby g36 » September 13th, 2021, 10:59 am
Welcome aboard
Been thanked: 490 times
Re: New member
Postby waybomb » September 13th, 2021, 6:41 pm
Welcome aboard.
Just about everybody by me uses blocks under the keel, spaced about every ten feet, and then 4-6 stands to stabilize the boat.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Re: New member
Postby pepmyster » September 13th, 2021, 6:58 pm
Welcome!!!!!!!!!!
Re: New member
Postby Viper » September 13th, 2021, 7:58 pm
Welcome aboard.
Users browsing this forum: No registered users and 37 guests
