Waste tank sensor
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Waste tank sensor
Re: Waste tank sensor
With a fresh pump out I fill about 1/2 with water and pour in a good cup or 2 of detergent. I let it slosh around on the trip out and use the other head while it sort of self cleans. After a day or so on the water it is back to the pump out to remove the tide and water.
That being said I do have plans to install a proper gauge to give me a more accurate reading. Some will recommend the tape type sensors mounted on the outside of the tank however I had one (original snake river) and it was problematic. I swapped out the main display for the new and improved model which worked but for only a couple of years. Sold the boat and the new owner had to replace the display unit again. After a few more years it once again died. The display contains all the electronics to make this work but as you can see it did not fair very well at all and on top of that they are several hundred dollars each time.
An accesible float for periodic maintenance made of stainless is something I am considering if I have the headroom to install one. https://www.fisheriessupply.com/wema-us ... ank-sensor
- pepmyster
8.1 Volvo Penta
- Has thanked: 603 times
I know you are not talking about the tank, this is just an anecdote about Stainless. Do your research.
Since only one size fit there and nothing was available, I welded up a stainless steel tank for him to the same dimensions. Wonder if that tank is still kicking.
Thanks for the heads up on the stainless.
Calibration.
- pepmyster
8.1 Volvo Penta
Midnightsun wrote:Source of the post That being said. Maybe these newer SCAD units work better than the Tech-Edge/Snake River units I had in the past. Seem to have good ratings across the board. Like the format. Decisions, decision, decisions! https://www.scadtech.com/tank_monitors
Did you have problems with the Tech-Edge unit? I had one on my boat and it seemed to work well. I have another set with three sensors I was going to list in the classified. Seems like they use the same external tank sensor that the Scad uses.
km1125 wrote:Source of the postMidnightsun wrote:Source of the post That being said. Maybe these newer SCAD units work better than the Tech-Edge/Snake River units I had in the past. Seem to have good ratings across the board. Like the format. Decisions, decision, decisions! https://www.scadtech.com/tank_monitors
I did however it was not the sensors, the main board/unit was the issue. 4 of them in about 11 years. Not going back to Tech-Edge/Snake river
Users browsing this forum: 96Voyager and 33 guests
