1986 Riviera Table Problem
- hubba46
- Vessel Info: 1986 Carver Riviera
- Has thanked: 3 times
- Been thanked: 5 times
- Been thanked: 1111 times
Re: 1986 Riviera Table Problem
On my boat there were two posts to support the table. You had to wiggle the table while pulling up and the posts would loosen. Then you could remove both posts (with more wiggling) then set the table down into the edges of the seating, then cover with cushions.
- hubba46
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
So replaced them with an RV liftable table. Stand alone but possible to jam it under a latch. Stable and possible to take it out on to the cockpit or shore.
- uchu
- Vessel Info: 1988 Carver Santego 2767 - Twin Mercruisers 4.3LX with Alpha-One drives
- Has thanked: 86 times
- Been thanked: 15 times
Phrancus wrote:Source of the post Smart first owner... In mine the two posts (aluminium) were intact but the parts where it is supposed to be held by in table and floor were completely worn out, cracked, unusable. Wobbling table and no replacement parts found.
True, but the OP wants to drop the table down to use it as a bed...
- hubba46
- Phrancus
- Contact:
Which is exactly what I can do by pulling a small handle, a spring helps to carry the weight.
