Gas smell coming from gas caps
- JimCarver
- Vessel Info: Carver Mariner 360 2004. 650 hours on the 6 liter Crusaders gas engines. We've owned the boat since June 2021.
A few hours after shutting off the engines on our '04 Mariner 360 with 6 liter Crusaders gas engines, a slight gas smell comes out of our gas caps. We dos have the full canvas enclosure on the rear part of the boat (see pictures) and that doesn't help, but still, is this normal? Since the smell goes away a few hours after the engines have shut off, I deduct that the heat from the engines is bringing the smell up to the caps.
Also, I kneel down and put my nose all around the engine area and the smell is definitely not coming from the engine room and only from the gas caps.
Thanks for your time giving me your opinion on this.
Re: Gas smell coming from gas caps
Get asked quite often on where my vent is located when fuelling, not many know about vented caps.
Midnightsun wrote:Source of the post That filler happens to be the same filler as mine. Could not find my tank vent so I started researching on where it could be. Found out they are built into the cap assembly! Bottom line is venting occurs at the cap so smelling some fumes there would be normal. See picture on the link. https://www.asap-supplies.com/products/ ... ent-305587
Get asked quite often on where my vent is located when fueling, not many know about vented caps.
Wow. I'm surprised to learn that they built some that way. If you look at the OP's boat with the canvas, those fumes end up inside the boat. Even if he didn't have canvas, then a slight breeze could/would also bring those fumes into the boat. I wonder how they handle the loop in the vent line? That's typically designed to trap any water that might get into the vent and allow it to drain overboard. Can't see how that could happen on an installation like the OP's.
You do not need a loop on these as water cannot get in like a typical hull mounted vent.
Perko makes several styles incorporated into the filler cap like above. The other advantage is when the tank is full and the vent wants to expel, it does so on the fuel nozzle (returns to tank) which turns it off just like as if the tank was full so no vent spills in the water. I have never smelled fumes on mine however I do have diesel so maybe not as noticeable? I also have a custom enclosure where the aux tank fillers are enclosed very similar to the OP.
- JimCarver
So what do you suggest I do to eliminate the gas smells possibly creating fumes? The seals inside seem in great condition.
What is OP by the way?
The seal only seals the filler so to say and not the vent. If the vent were to be sealed it would not be a vent anymore. The only fix I can see is to remove the vent line attached to the filler port and relocate using a standard hull type vent.- bud37
- Has thanked: 602 times
JimCarver wrote:Source of the post Hello,
Have your canvas guy adjust the side curtain to go inboard of the vent/fill.....it should be that way anyway. I am sure if you show him/her the problem a solution can be met......good luck and keep that side curtain off that area until it gets looked at.
There will be an issue with water drainage but choose the lesser of the evils.......these people can be quite creative.
You can only do that if you cap off the vent port on the deck fitting otherwise you run the risk of overflowing fuel into your bilge.Midnightsun wrote:Source of the post..... The only fix I can see is to remove the vent line attached to the filler port and relocate using a standard hull type vent.
- JimCarver
I think the simplest option is to modify the canvas while finding a way to reroute the rain water away from inside the boat. Like you say, canvas people can get creative sometimes. And a bit of water is better than a lot of fire! If I don't like sometimes getting wet, I'll just stay home, and that won't happen.
Have a sweet Sunday!
Users browsing this forum: No registered users and 61 guests
